Th Fury engine detail project
Discussion in 'Cosmetic & Restoration' started by OrthmannJ, May 21, 2013.
  1. wixom61
    wixom61 Well-Known Member
    Dallas
    :slap: :disagree: :naughty::boxing::yikes::rulez::eek::bs:
    David :p
  2. OrthmannJ
    That is the plan I have right now going forward. You can't see it in the pics, but there is a valve plumbed into the heater line so I can manually turn the water off from going into the heater core. When I was driving the car in High School the vacum controled heater and A/C controls stopped working. My dad and I wired in a switch under the dash to turn on the blower motor so I would have heat and defrost in the cold months and then in the warmer months, I could just turn the water off so the heater core wasn't blowing hot air inside the car.
    Blasphamy!
  3. Olds Weighty Eight
    Olds Weighty Eight New Member
    Memphis, TN
    I had a '68 Firebird that had a similar issue with the heater control but I plumbed a 1/4-turn ball valve into the line as opposed to a water spicket valve. That does look pretty funny in there. :yup:
