what engine now?
Discussion in 'General Automotive Tech' started by rancheronut, Jun 3, 2010.
what should i do with uncle buck?
Poll closed Sep 1, 2010.
  1. pull oil pan and just REPLACE the bearings in the olds 307
    0 vote(s)
    0.0%
  2. compete rebuild the olds 307 and add some aftermarket parts
    4 vote(s)
    18.2%
  3. swap in a other olds engine like a olds 350 in place of 307.
    8 vote(s)
    36.4%
  4. swap a 400 SBC CHEVY & 7004R
    1 vote(s)
    4.5%
  5. swap in a COMPLETE TBI 350/305 drive train from a 1987or up caprice
    6 vote(s)
    27.3%
  6. do nothing, let it sit for another 10 yrs!
    1 vote(s)
    4.5%
  7. SELL THE CAR.
    2 vote(s)
    9.1%
Multiple votes are allowed.
  1. silverfox
    That 307 may just be suffering from the typical Olds plugged oil returns. Clean them out and you may find that the engine will run quietly.
  2. phantom 309
    phantom 309 havin a laugh
    here
    duramax for the win,. power and mileage,.
    6.2 diesel is an easy swap,.
    350 olds , 9:1, #7 heads with tight quench,close lobe centres with a large lift,(dual pattern larger on the exhaust side) decent dual plane aluminum intake, carter 650 carb,(called edelbrock now) decent set of long tubes, 3:42's, build the 200R4 properly,.use a 2200 stall in it,. with a manual lockup switch,. driven right it'll do over 20mpg and still have very respectable performance,.
    JMHO,.
    Nick
  3. rancheronut
    rancheronut New Member
    montana
    well the 307olds and 200-4R are gone. after I pulled the 307 . I took the 200-4R off the 307 olds and sold 200-4R for $100 . I then removed the engine mount on frame and installed the SBC one's in the right location’s.
    it only took 5 minutes to move them. these are the tools i used.
    in it place is the SBC 350 and 700-4R.
    right now, I have the the SBC/700 installed and every thing hook up on the underside except the exhaust to manifolds connection. did all that from 3 pm to 9 pm tonight.
    now the fun part of switching all the electrical. like remove the driver side battery box and wiring, then installing it on the passenger side.
    funny thing ,was when I went to install the 350/700 .my cherry pick couldn’t reach far enough back to install them. so I had to use a floor jack under the tranny and move both chains from the cherry picker to the front on the SBC. then I could move the engine and tranny back, so to line up the 2 half of engine mounts and transmission mount. this is the same cherry picker, I used to pull the 307 and the 350 out of both cars but couldn’t reinstall the 350 in the Buick. strange:confused::coco:.
  4. silverfox
    Lookin' GOOD, ranch!(y) Now the work begins. But, it will be worth it in the end. Good job.:tiphat:
  5. DrCAS
    DrCAS Active Member
    St Cloud, MN
    I vote to put in a 350 Buick motor. Those things are freaking bulletproof.
  6. DrCAS
    DrCAS Active Member
    St Cloud, MN
    I got a 3.8 Turbo motor for the Astre...
  7. rancheronut
    montana
    sorry i already have SBC 350 and 700-4R installed. if it just stop getting below 20* or colder on my day off. i could work on all the wiring. plastic don't like cold weather.
