Trailer Wiring question
Discussion in 'General Automotive Tech' started by zzzizxz, Dec 2, 2018.
  1. zzzizxz
    zzzizxz Well-Known Member
    Cincinnati, Ohio
    Thank you!!!
    Based on that, my 5-pin connector is at least 1/2 inch wider across than yours, and I do have the right 4-pin. I guess I'll be cutting that 5-pin off and installing a standard sized 5-pin!
    Thank you so much!
  2. HotRodRacer
    Northeast Tennessee
    Interesting! Well, glad you got it figured out. I have never seen a flat-5 as large as yours, but apparently they are out there!
    You're welcome, glad I could help.
  3. joe_padavano
    Northern VA
    The flat five pin connector is the one that came from GM with the now missing mating pigtail. The five wires are the green and yellow turn signal wires, the brown tail light wire, a white ground wire and a blue aux wire intended to connect to a trailer brake controller.
  4. zzzizxz
    Cincinnati, Ohio
    Do you have any idea the part number of that mating pigtail? Or any leads no how I could find that/what to search for?
    I know I can just cut it off and rewire a connector, but if I could find that pigtail, it would make things easier.
    Thank you!!
  5. joe_padavano
    Northern VA
    The GM part number is 2987124, Harness, Trailer Wiring. It's been out of production for decades, so don't expect to find one.
  6. HotRodRacer
    Northeast Tennessee
    Joe you are a wealth of info. :thumbs2:
  7. HotRodRacer
    Northeast Tennessee
  8. HotRodRacer
    Northeast Tennessee
  9. HotRodRacer
    Northeast Tennessee
    Only two I found.
  10. joe_padavano
    Northern VA
  11. zzzizxz
    Cincinnati, Ohio
    Oh, so this was not a GM specific plug that came with a step-down attachment to fit the standard trailer plugs, this was just the size that trailer plugs were at this time?
  12. joe_padavano
    Northern VA
    It appears that you can buy aftermarket ones on Amazon.
