Lincoln Wagons?
Discussion in 'General Station Wagon Discussions' started by Xavier, Jan 26, 2012.
  1. Krash Kadillak
    The main problem is that while the Crown Vic and Grand Marquis have the same basic bodies, the Town Car has always had a completely different body - different contours on the body sides.
    - You could swap a Grand Marquis front door onto a Crown Vic, and it would fit fine, but you couldn't do that with a Town Car door - body lines on the outside wouldn't line up*.
    As Patrick said, you could turn a Crown Vic or Grand Marquis wagon into a Lincoln, but it would be A LOT of work.
    *Size and shape of the door window frames isn't the same, either.
  2. patrick80
    patrick80 Wagonista!
    OK
    The frame issue could be solved by using the Ford/Merc window frames and glass. Again, a LOT of work.
