Bagging an 86 Olds Custom Cruiser
Discussion in 'Station Wagon Projects' started by TylerTJ, Jan 31, 2017.
  1. ModelT1
    Well--------------- I've never had an 86 Mercedes.:90:
    Tyler, now I understand. Maybe this is why so many vehicles that look great on those "lists" don't sell.:huh:
  2. TylerTJ
    TylerTJ Active Member
    Does anybody know of a steering wheel adapter that will fit this car? I want to put a nice steering wheel on my car, and I can’t find anything that would work.
  3. Fred Kiehl
    Fred Kiehl Well-Known Member
    Largo, FL
    I depends on the wheel. If you have a 3 or 5 bolt, the Grant and their adapter will fit. You just have to make sure the dish/adapter combo is about the same as the original wheel to turn signal stalk, so you can comfortably reach the turn signal stalk, and shift lever. If you are going to use a 6 bolt (MOMO or Nardi), there are adapters that fit the Grant base and give you the correct height with a given dish. If you want a 9 bolt or large diameter 6 bolt, there are adapters from Moto Lita that can be adapted to the Nardi, MOMO, and maybe the Grant. So find the wheel you want, send me the hole pattern/diameter/type, and I can probably figure out which adapters will work with it.
  4. OrthmannJ
    Are there any controls on your steering wheel? Such as cruise control?
  5. Fred Kiehl
    Largo, FL
    If you look at the picture on the previous page, you will see that it does not have any controls on the steering wheel.
  6. OrthmannJ
    The photos on the previous page are of the parts car.
  7. TylerTJ
    Nope, just horn buttons.
  8. OrthmannJ
    Then I would say most aftermarket wheels should offer an adapter that will work with your setup. I haven't done many aftermarket steering wheels, but I do know that Grant offers a large selection. I have used them in the past and was happy with the product.
  9. TylerTJ
    Help please.
    Does anybody know why my front passenger door switches don’t work? Door Lock switch does not work. Window switch will not roll down, but it works fine to roll it up. I’ve replaced both switches. Everything works fine from the drivers side.
    Any help?
  10. Fred Kiehl
    Largo, FL
    Do you have a VOM? You need to check for voltage, and ground at the connectors. You may have a broken wire, or a connector somewhere in the ciruit may have a loose or corroded pin.
  11. OrthmannJ
    I agree. My first thought was the wiring. Could be a bad ground, but likely a break or loose connection somewhere.
  12. Hernandez6609
    Hernandez6609 New Member
    Beautiful Wagon!! Did you use 2500lbs bags all around?
  13. BKenny
    BKenny New Member
    Wow the rims and stance give a whole new look!
  14. 89oldsCC
    89oldsCC New Member
    hey Tyler, been going back and checking out your build every once in a while. Waiting to have the funds around to bag my 89 CC, would love a parts list for all the pieces you used for your kit. love the look and hope mine looks like it soon, laying frame and going slow.
