73 Satellite Waygun Revival
Discussion in 'Station Wagon Projects' started by waygun, Mar 17, 2019.
  1. KenBird
    KenBird Active Member
    Saskatoon, Saskatchewan, Canada
    Lookin' good.:thumbs2:
    Ken.
  2. OrthmannJ
    I agree, it is looking real good.
  3. waygun
    waygun Well-Known Member
    Kingston,Ontario
    More work done today..
    My buddy James did his magic on the 'teen's heads.
    3 angle grind job,new valves,340 springs..
  4. waygun
    Kingston,Ontario
    Cleaned up the oily mess mixed with clutch dust..
  5. waygun
    Kingston,Ontario
    Scraped and cleaned the frame cross member and shot coat of chassis black.
    With no power steering or other accessories,this is in plain view when the motor is in the bay..
  6. waygun
    Kingston,Ontario
    Finished up cleaning the engine bay as much as I wanted to.
    Decided not to do the firewall.
    Once the motor is back in , most of the firewall will not be as visible.
    I like the old patina look.
    I am doing a revival--not a full blown restoration,LOL
  7. waygun
    Kingston,Ontario
    Camshaft and crankshaft installed,
    Checked the deck height in this pic...Typical 70's low compression where the slugs sit waaaay down in the hole,LOL!!
  8. Silvertwinkiehobo
    Oh, but you'll correct that, come time to warm that mill up.
    waygun likes this.
  9. waygun
    Kingston,Ontario
    Building an engine nowadays even when doing 95% of the work is not cheap.
    We were lucky that the block and heads did not require any outside machine work.
    Using the original pistons (the block did not need boring) cut costs dramatically.
    If the block needed an overbore it snowballs from there---new pistons,then the rotating assembly needs balancing and on and on it goes....I have been there!
    But I digress..luckily the wagon motor was in very good shape and we are moving forward with what we got.
    Simple old school bolt on power boosters is the name of the game. Bigger cam,intake and headers al8ng with the massaged cylinder heads will make torque and powet to pull a heavy car and whatever else I haul with the damn car,LOL!
  10. KevinVarnes
    Any updates on this project?
  11. Silvertwinkiehobo
    Yeah, hopefully you decked the block to bring compression up a smidge.
