73 Satellite Waygun Revival
Discussion in 'Station Wagon Projects' started by waygun, Mar 17, 2019.
  1. KenBird
    KenBird Active Member
    Saskatoon, Saskatchewan, Canada
    Starting to look good under the hood. I guess it was a good idea back in the day to do that for daily drivers down east to keep it from returning to the earth, a little elbow grease to get off is better that replacing panels. Not so much worry now that it gets cared for a bit differently, these aren't just an "old car" anymore, they are a cool piece of history.
    Ken.
    waygun likes this.
  2. OrthmannJ
    Wow, I'm impressed with how nice the paint is under the protective coating.
    waygun likes this.
  3. waygun
    waygun Well-Known Member
    Kingston,Ontario
    Picked up the block this morning..all clean and cylinders honed... thumbnail_20190325_092936_resized.jpg
  4. waygun
    Kingston,Ontario
    Original flywheel was machined for the new Hayes clutch..
  5. waygun
    Kingston,Ontario
    Rebuild kit arrived during lunch.Getting stoked!
  6. OrthmannJ
    Everything looks good!
    Can't blame you.
    waygun likes this.
    The deck must've been in exceptionally great condition; I didn't see any pitting around the water holes, nor any fire ring compressions around the bores. Very nice. My 351W needed about 3 thou off one deck, and 4 thou off the other in order to clean them up for new gaskets.
  8. waygun
    Kingston,Ontario
    Very good shape. Low miles on it and were easy,babied miles.
    it was just old and tired. Oil rings were stuck in the groove of the pistons creating blow by.
  9. Silvertwinkiehobo
    That's likely from sitting. So did you go 30 over on the cylinders?
  10. waygun
    Kingston,Ontario
    No doubt. We measured the cylinders and bore was not needed. When you bore them out the cost of machining and new pistons go through the roof.
  11. Silvertwinkiehobo
    That is good. Your engine really didn't go through much, so that is very lucky.
  12. waygun
    Kingston,Ontario
    Cam bearings and frost plugs installed..shot coat of primer and Chrysler corporate blue...
  13. waygun
    Kingston,Ontario
    Pistons in soak they are so full of carbon..
  14. waygun
    Kingston,Ontario
    Thanks to my buddy James,he is massaging the heads for better flow.
    Nothing really crazy but make them flow better for efficiency.
    Also port matching to the gaskets and intake manifold....
  15. waygun
    Kingston,Ontario
    The archaeological dig for original paint beneath the Ziebart continues....impressive I must say.
    Still got a few days worth of cleaning and detailing to do..
