Newbie: Here is my 1979 Dodge Aspen R/T Sport Wagon!
Discussion in 'General Station Wagon Discussions' started by PLY478, Mar 6, 2013.
  1. PLY478
    PLY478 Member
    Central WI.
    Hello all. Been a lerker for some time now. Here is my 1979 Dodge F-Body for your viewing.
    It is my version of a what if car. A combination cross of the scarce Aspen Sport Wagon and the 2 Door R/T Coupe. All the work was done by myself. Was a bench seat auto on the colum car. 225 leanning tower of power.
    Here is where I need some help with parts:
    List needed: 360 / 727 Conversion
    I need all the kick-down linkage for a LA 360 4bbl / 727 Complete all the springs etc.
    I need a Factory V8 Radiator for Automatic, with A/C (Must be an original part in nice condition)
    Need rear frame sway bar mounts that bolt to the frame rails. ( I have the bar )
    Need a steel LA 727 Trany Dipstick and tube. ( Nice Original Parts )
    Need a Steel 360 engine oil dip stick and tube. (nice Original Parts )
    Nice complete un-cut 360 w/A/C engine wiring harness. (No junk please)
    Nice Original Chrome trim for the gas petal. ( Original Part )
    PM me here or call.
    715-297-4041
    Thanks Rich
      File size:
      72.6 KB
      53
      File size:
      85.7 KB
      56
      File size:
      81.8 KB
      58
      File size:
      68.1 KB
      52
    WagonTheDog likes this.
  2. PLY478
    PLY478 Member
    Central WI.
    More pictures:
      File size:
      86.5 KB
      49
      File size:
      86.2 KB
      46
      File size:
      85.9 KB
      47
      File size:
      73.7 KB
      47
      File size:
      71.3 KB
      49
  3. n2fordmuscle
    Canton, GA
    Awesome wagon!! Good luck with your parts search, and keep us updated.
  4. PLY478
    PLY478 Member
    Central WI.
    Here is a picture of what I started with. I am the second owner. I was after the car for 10 plus years. In my name for about the last 3 years now. I drove it as is for about two years. Then I parted out a 1979 Aspen Coupe for the front seats, console, and rear seat cover. The coupe interior was all Saddle color. I dyed all the seats, console and re-dyed all the other wagon interior parts. All new carpet set etc. I even dyed a Black Tuff wheel to match. I liked the look better. All the flares came from collecting parts over the years. I rebuilt the 8-track Radio ( Took me 3 units to make one that worked. The wheels are Original Parts. I restored them. Added dual Sport Rear View side mirrors also.
    The cars state right now is apart. I am doing detail and repaint under the hood. Installed a new radiator core support for the larger radiator. It will have a warmed over 71 360 engine. It will have a factory cast iorn 4v intake with a Thermoquad carb. And Orange Dual Snorkel Air cleaner. motor will be Factory Blue in color. Trany is a slightly modified 727 with a factory 360 HP converter from a 72 Rallye Charger. ( Its New Old Stock ) Rear end will be an 8.25" sure grip. Gear ratio undecided at this time.
    So please if you can look at my parts needed list in the first post. Please help if you can.
    Special Thanks to Marty, for some really odd parts that I needed. And to Jim the Deconstructor! Both GREAT guys to work with!
    In final: I am trying hard to get this car done for this summer. As it has been apart for over 1 year now.
    Thanks
    Rich
  5. jrwscout
    jrwscout New Member
    Kansas City, MO
    Welcome aboard! Great job on your wagon!
  6. Termite Free Woodie
    Termite Free Woodie New Member
    Co.
    :Welcome: Nice job. I always wanted to see what one would look like done in an R/T conversion! :woohoo1:
  7. Olds Weighty Eight
    Olds Weighty Eight New Member
    Memphis, TN
    That's a unique, one-of-none car that will cause some head scratching at car shows. :hmmm: Very nice!
  8. 1tireman
    1tireman Well-Known Member
    Slidell, Louisiana
    Nice lookin' wagon. :Welcome:
  9. 81X11
    81X11 Well-Known Member
    Round Rock Texas
    Never seen such a thing. VERY cool!
    -Mike
  10. PLY478
    PLY478 Member
    Central WI.
    Thanks everyone! Glad you like my idea! It does turn heads. And with a little luck this summer it will be turning both rear tires!
    PLY478
    Rich
  11. MikeT1961
    GREAT car. You started off with a beauty, and sure did a great job on the conversion. Simply beautiful. Great plans you have, too. May I make one suggestion, though, for the 360: Skip the cast iron factory intake. Go with an Edelbrock Performer RPM. It flows better, which gives better power as well as slightly better fuel economy. Most importantly, it helps take a bit of weight off the front end for better handling. Every pound counts. It can be painted to look like the factory original part, too.
  12. Krash Kadillak
    Nice work. When these came out, I so much wanted one (the Sport Wagon package). Budget at the time wouldn't permit. You've done a lot with what you have. One question: How are the dyed interior parts holding up, and what products(s) did you use?
    Marshall
  13. 1OldFordMan
    1OldFordMan New Member
    St. Charles County, Mo.
    Nice job. Looks great!!! :thumbs2:
  14. jmt455
    jmt455 Well-Known Member
    SE Michigan
    Welcome aboard, Rich!
    VERY nice job on your special wagon!
  15. unkldave
    unkldave Cockroach Dave
    Lincoln City Oregon
    Well,.. I like it! You're in as far as I'm concerned! Welcome!
