Ram Air Hood for 72 Lemans
Discussion in 'Cosmetic & Restoration' started by Ghazi67, Mar 22, 2018.
  1. Ghazi67
    Ghazi67 Member
    Jubail, Saudi
    Hello
    Hope all are well
    Donno if I am in the right place .. But I plan on replacing my 72 Lemans hood with a 68-70 Ram Air hood ( similar to pic below ).
    I am looking for a steel hood ( if any ) .. Any advise is welcomed
    Thanks
  2. Ghazi67
    Ghazi67 Member
    Jubail, Saudi
    Maybe I am in the wrong section !! :racingflag:
  3. KevinVarnes
  4. Ghazi67
    Ghazi67 Member
    Jubail, Saudi
    Thanks for your reply Kevin
    Actually I am going for the "Looks" , but with one that follows the 72 Lemans Endura lines ( as pictured above )
  5. KevinVarnes
    Well from the sounds of it somebody made that hood by combining a '72 LeMans hood with a '68-70 GTO hood so you probably aren't going to find that hood anywhere.
    http://www.pontiaczone.com/forum/showthread.php?t=15059
    Best bet is to have a competent body man make it. My guess is your options will be limited in anything else if you want to retain the front end that you have on there now.
    CammerJeff might have some other insight. He seems to be the resident Pontiac expert.
    Ghazi67 likes this.
  6. elB
    elB Well-Known Member
    NorCal
    That's not a Lemans endura hood or front end, that front end is fiberglass. The endura front end (T-47) hood for a '71-72 Lemans is worth about $3500-5500 if you can find one that isn't rusted. What someone did is probably graft a section of a '68-70 GTO hood on a '71-72 Lemans hood in that picture.
    The standard '68-70 hood won't line up with the '71-72 front end as the bulge in the '68-70 hood doesn't taper off like the photo.
    Ghazi67 likes this.
  7. KevinVarnes
    ...or elB our other resident Pontiac expert.
    Ghazi67 likes this.
  8. Ghazi67
    Ghazi67 Member
    Jubail, Saudi
    I will consider this ... Thanks alot
  9. Ghazi67
    Ghazi67 Member
    Jubail, Saudi
    I got that feeling when I couldn't find any on the net. I guess I have to graft that section, or replace the whole front end
    Thank you Sir
