Edelbrock 600cfm fuel pressure
Discussion in 'General Automotive Tech' started by hoghead, Oct 25, 2011.
  1. hoghead
    hoghead New Member
    Grand Junction, CO; CO native
    Was having problems with the Edelbrock 600cfm carb (I thought) on my 400 Pontiac - just could not lean it down. Wouldn't idle smoothly. Wasn't terrible - no black smoke, etc., plugs burning OK but, was very touchy on hot start. Never failed to start but, don't even think about touching the accelerator pedal - it would flood. An additional frustrating symptom was that it would just quit at about 70mph when under full throttle from a dead stop, but would run normally immediately after letting up on the pedal. Yet...it would not do that every time (aaaargh!) I changed jets, metering rods, springs, accelerator pumps, numerous times; checked for vacuum leaks, played with timing, went through the distributor, etc., etc. Still had the problem. Then, I read that this carb does not like fuel pressure above 5psi. Put a fuel pressure gauge on the line...the needle at idle was a blur between 3 - 7 PSI, and between 5 -9 psi as throttle was advanced. So...a new mechanical OEM fuel pump settled it down to a slow needle pulse between 4 1/2 - 5 1/2 psi; a Holley pressure regulator adjusted it to a steady 5 psi. Gas mileage jumped up 2 mpg. Noticeable increase in power and torque. Idles smooth. Ol' "hoghead" learned a lesson. Hope this info is useful to others on the forum.
  2. silverfox
    I had that same exact problem once with that same carb.:yup:
  3. 84 bowtie estate
    84 bowtie estate Active Member
    lake saint louis mo.
    i have been fighting something similar on an 84 305 upon hot restart after sitting about 5 min. took off the lid of the carb and was watching the fuel boil in the bowls. i hear that is common on aluminum intake motors.:taz:
  4. hoghead
    hoghead New Member
    84...don't know how common it is but, have witnessed several of my buddies alleviate that problem with carb spacers of various thickness. The spacer provides a better thermal break between carb and intake. Thickness of an inch, or more, will also provide a small, but noticeable, increase in power and slightly better gas mileage.
  5. ModelT1
    ;) Yep on all of above. Keep PSI around 5 with regulator and use as tall a spacer as you have room for. :)
