Aftermarket Radio
Discussion in 'General Automotive Tech' started by pyasher, Sep 13, 2015.
  1. pyasher
    pyasher Well-Known Member
    Columbus Ohio
    Any recommendations on a good aftermarket radio? Must appear stock and have high power and Auxiliary inputs...
    For what car?
  3. 59 wagon man
    hollywood fl
    retrosound
  4. pyasher
    Columbus Ohio
    1972 Chevelle
  5. 59 wagon man
    hollywood fl
    the retrosound has adjustable post to fit any dash ,can control numerous amps,has usb connections and aux in .i have it and love it compared to the custom autosound i had.
  6. elB
    elB Well-Known Member
    NorCal
    Yup. Custom Autosound was expensive junk and I'd never recommend them to anyone. RetroSound won't be a big bass thumper on its own, but it has all of the sub and amp options built in to make a really nice system. It will also work in practically any car:
  7. pyasher
    Columbus Ohio
  8. n2fordmuscle
    Jasper, GA
    Another vote for Retrosound. I've got one in my Montego wagon.
    pyasher likes this.
  9. pyasher
    Columbus Ohio
    These folks seem to have a good product also. $410.00 to convert my factory radio. Www.turnswitch.com.
  10. KevinVarnes
    Not real cheap, but that is pretty cool.
  11. Eagle Freek
    Eagle Freek Well-Known Member
  12. pyasher
    Columbus Ohio
    I would like to keep it simple and use the radio in the dash. I do
    Iisten to FM but I also take the Wagon on longer trips and do not want to hunt for stations. I really like the USB. input which can be controlled using the tuning knob. Thanks for the input!
  13. 59 wagon man
    hollywood fl
    i was very happy with the retrosound using thumb drives loaded with music
  14. pyasher
    Columbus Ohio
    I will be making a decision soon - winter project - it will be Retro sound or Turn switch - thanks everyone for all the advice!
  15. crownvictoria
    crownvictoria Member
    southern Germany
    sorry to jump in, but are you sure?
    I believe a 3,5mm headphones output is a high level signal while an amp only is able to use low level signal via the cinch connectors. Not sure if this would burn your amp. Although some amps are equipped with high level signal inputs, these are all meant to accomodate speaker cables from the head unit (in case the head unit has no cinch output).
    At least that´s my experience so far with car hifi systems....
