6VDC and 12VDC in the same vehicle!
Discussion in 'General Automotive Tech' started by Stormin' Norman, Jan 12, 2010.
  1. Stormin' Norman
  2. eshaver
    eshaver New Member
    Richmond Va
    Norman, on my 53 Ford F-100 I have run a volt - A drop resisistor to cut the voltage from 12 to 6 . Meanwhile the ballast resistor drops voltage to the points to 9 V. The heater employs a 56 12V motor . Ed Shaver
    Yeah, I did similar things to a 1953 Chevy sedan delivery. 6 volt vehicles have lower gauge wiring (thicker). Its when you want to add new, more delicate circuitry that the old tricks sort of don't deliver properly. I like the old simple solutions far better, because you can fix them quickly.:bowdown:
