62 Pontiac 4 speed automatic questions
Discussion in 'General Station Wagon Discussions' started by kolby66, May 2, 2012.
  1. kolby66
    kolby66 Well-Known Member
    az
    Anyone have experience with the GM, Super-rotomatic or Jetaway? Mine is slipping, and will not up shift. However if you are driving about 20mph and stomp on it, it will down shift. Do these transmissions have a parking pawl? my car still rolls when in park. I am trying to figure out if the trans is shot or just needs some tlc. Thanks for any information. Andy
  2. Krash Kadillak
    Wish I could help you. Had one of those in a '64 Pontiac Ventura, but never had transmission issues for the short time I owned it.
    Keep searching.......
  3. MotoMike
    MotoMike Well-Known Member
    Newnan, Ga
    Don't know the particulars but from what I've read, these transmissions do have more than average problems.
  4. 1967 Tempest
    NPR, Florida
    Have you adjusted the TV cable for the down and upshift? Yes, they do have a parking pawl.:yippee:
  5. 65 2dr
    65 2dr Fix 'em all -
    Chicago Area
    I believe the T-400 was a direct bolt-in!
    I know Olds dealers were doing it under warrantee, to avoid the warrantee/comback problems!
  6. kolby66
    az
    The 62 engine has the started mounted to the transmission bell housing, a TH400 will bolt up but you can not mount the starter. Thanks
  7. Safari57
    Safari57 Well-Known Member
    Vancouver Island, BC
    I know you can buy adapters that provide the starter bolting, but I built my own when I had the 389 from a '64 in the wagon. Just did a template off the old tranny, torched it out, cleaned it up, welded nuts on the backside where the starter bolts to, painted it up, and in it went. Worked perfect for many years. Was able to run my T400 without issues.
