Some Wagons In A Local Junk Yard
Discussion in 'Station Wagon Auctions, Craigs List and Other Stat' started by yellerspirit, Nov 26, 2017.
  1. yellerspirit
  2. 101Volts
    101Volts Well-Known Member
    Pennsylvania
    I'm starting to think a lot of these pre-1950 something cars might last a lot longer sitting out in a field than many newer cars; most of the rust (not counting the floor) I see on that 41 Ford seems to only be surface rust. I don't know how long they sat in the weather, though.
    ModelT1 likes this.
  3. jim535
    jim535 born in a Ford
    Ottawa, Ontario
    $16,500 for the Pontiac Safaris does seem a might steep.
    101Volts and ModelT1 like this.
  4. ModelT1
    I have a special yearning for the '41 Ford woodless woody!
  5. yellerspirit
    ModelT1 and 101Volts like this.
  6. ModelT1
    Poison_Ivy likes this.
  7. yellerspirit
    You could always go to Home Depot, I'm sure it can't be that hard to make a station wagon body. :biglaugh::rofl2::slap:
  8. uncledave
    uncledave Active Member
    Hartly DE
    not sure but I think 16,500 is for the green and white one. the '57 is another 8900. Neat cars though, rare as hens teeth.
  9. DBdually
    DBdually Well-Known Member
    Montpelier, Va (Richmond)
    WOW! A ‘69 Dodge with cornering lamps!!! I don’t think I’ve ever seen a Dodge Wagon with cornering lamps... and they look so unusual. I believe the Monaco’s of the same era had a three section cornering lamp. I’m not sure what else I’ve seen these on!?
