Replacement front springs for 1986 Colony Park
Discussion in 'General Automotive Tech' started by ldv9463, Jul 14, 2020.
  1. ldv9463
    ldv9463 New Member
    Hi, does anyone happen to have the front OEM coil spring specifications for a 1986 mercury colony park? If so, that would be much appreciated. Thanks
  2. Tomab
    Tomab Member
    Chicago, IL
    I could not find listed specs for your wagon, however I did find many different sites including Ebay, Amazon, RockAuto, and ShockWarehouse which sell a MOOG 8795. These websites indicate that the part is a direct replacement for an `86 Mercury Grand Marquis Colony Park 4-Door Wagon.
    Then searching on MOOG's website I dug up the following information:
    ID - 5 Inches
    ID - 127mm
    Bar Diameter 0.62 Inches
    Bar Diameter 15.90mm
    Spring Rate - 182 lbs per inch
    Load 790 lbs
    Installation Height - 12.69 Inches
    Installation Height 322.30mm
    Free Height 17.04 Inches
    432.80mm
    Pigtail ends on both with a constant rate spring type.
    Design load - 1100 ??lbs??
    No bushings included.
    8.16 coils with an outer diameter of 6.260 inches.
  3. ldv9463
    ldv9463 New Member
    I appreciate the help, but i need the OEM specs. I replaced the rear springs with MOOG springs with what I thought were OEM height, but actually ended up being a couple inches shorter and so now my wagon is squatting. I don’t mind the look so I’m going to try and lower the front as well the same amount as I lowered the back, so I need to know what the front spring OEM free height is. Thanks
  4. Silvertwinkiehobo
    Seguin, TX
    I don't think there is a free spring height specification, but there is a body ride height specification. You can Google it, see if it's on the Net.
  5. 60Courior
    60Courior New Member
    You could always just cut a coil off each front spring to lower it where you want it.
  6. Grizz
    Grizz Are we there yet???
    Nashville, TN
    How about some airbags? I think it was a factory option
    Seguin, TX
    On the rear, and IIRC, the sensor did have three adjustment notches. The only Blue Oval car I know of with four-corner airbags was the FWD Continentals.
