this is the engine and trans in my 59 wagon?? Can anyone assist on the number on my three on the tree transmission believe they are: A3-7222-? ? 16 can not make out two numbers where ? Are. 30 AF-7006-D Engine is a C2AE 292 year 62 car or 62-64 truck Can’t work out trans for new clutch. Many thanks in advance
It doesn't really make any difference. The clutches are pretty universal for that year. If you have a synchronized first gear, you will need a fine splined plate, if non-sychro it will be coarser. Also, depending on whether it is a standard or heavy duty clutch, it will be either 10 or 11 inches. Pull the clutch and measure and count, then go from there.
You didn't answer my question about having a syncho first gear. That transmission first came out in 1963, and I believe it had fine splines. Previous transmissions did not have the first gear synchro and I believe they only had 9 splines. The clutch covers are all the same, only the clutch plate is different. A phone call to your supplier telling them you need a 23 spline plate should get you working.
