fuel neck grommet
Discussion in 'General Automotive Tech' started by crankshaft20, Jan 20, 2013.
  1. crankshaft20
    crankshaft20 New Member
    Bakersfield ca
    my 73 country squire the fuel neck grommet leaks bad anyone know where to get a replacement grommet
  2. MikeT1961
    Check your local Ford dealer. The filler necks are all the same diameter, so they are still using the same gromet on a lot of the new tanks. When I needed one for my 88 Crown Vic, it took 12 hours to have it at the dealership, and was under $10. Being a vertical tank, I would bet it is the same grommet as you need for your old Ford.
  3. crankshaft20
    Bakersfield ca
    going to have to do that i can not find one any were thank you
