Ford fuel sender - rebuild?
Discussion in 'General Automotive Tech' started by Dazza_P, Aug 16, 2017.
  1. Dazza_P
    Dazza_P Member
    Hi Everyone,
    I have been troubleshooting a faulty fuel gauge in my 1968 Country Squire and have discovered that the fuel sender is faulty. In searching the forums, I also see that these senders were made for the wagon only and are quite difficult to find nowadays. I wanted to see if anyone has had any experience in repairing/rebuilding a fuel sender (considering they are so hard to find). I would assume the electronics would be the same as a standard Galaxie sender.
    Any input/leads on replacement senders or repair methods would be appreciated.
    D
  2. Poison_Ivy
    There shouldn't even be electronics in something that old. It's a simple gadget consisting of copper windings, similar to how an electric motor is wound. The insulating clearcoat covering the copper thread isn't likely damaged, since there is no frictional contact between that and its surroundings. I'd inspect the electrical contacts which might be corroded or look for a punctured float.
    Dazza_P likes this.
  3. ModelT1
    Usually it's a bad float, pin holes, fuel inside it, maybe rusted holes in the pick up tube. Even rust scale preventing it from moving up and down.
    Very possibly the sock filter at the end is plugged.
    I've cleaned and rebuilt them but was eventually lucky to find a new one.
  4. Grizz
    Grizz Are we there yet???
    Nashville, TN
    What's it doing? I'd go with ivy and clean the contact that moves up and down with the float. The senders are fairly simple gadgets. On my cp the fuel gauge was all over the place when I first got it. After running a few full tanks of gas it straightened itself out. My guess is the gas was old and maybe the contacts on the sender got a little residue that eventually affected the reading. I love the rare occasion when the car fixes itself.
    Dazza_P and ModelT1 like this.
  5. Dazza_P
    Dazza_P Member
    Thanks for the advice everyone
    Ivy was correct, pulled the (very, very) rusty sender and found the float was not floating and the sock filter not attached. Have parts in order!
    Cheers
    Grizz and ModelT1 like this.
  6. Poison_Ivy
    My '56 Chevy had a tank drain plug, so that you could rid of condensation. If you didn't get into the habit of draining it regularly, the tank would rust anyway. It was always important to fill the tank to the brim. I never saw drainplugs on 60's and up cars. Maybe, auto manufacturers knew that very few people practiced such routine maintenance, anyway. The sealed systems, starting emmission control times made draining obsolete.
    ModelT1 likes this.
  7. Grizz
    Nashville, TN
    ^^^the Evap system maybe? Thanks for the pic dazza! Love pictures. Especially when reading books
  8. Poison_Ivy
    Yes, indeed. That closed loop system with that carbon canister.
    Dazza_P likes this.
  9. ModelT1
    A '55 Chevy wagon is a real pain to remove the sender or tank. It's built around the differential so the suspension has to be all but removed. I've had a lot of '55 Chevys and the wagon sender was hardest to buy new. Then getting the float to float in the right position is another pain. I never let the fuel gauge get below 1/4th just in case.
    Sadly now laws make salvage yards punch holes in fuel tanks.
    Poison_Ivy likes this.
  10. Grizz
    Nashville, TN
    Yeah dazza! You forgot to mention that p0420 code it was throwing!
  11. Poison_Ivy
    It's more fun shooting holes into them, Sir.
