Ford C4 Ring Gear R&R
Discussion in 'General Automotive Tech' started by Stormin' Norman, Apr 10, 2009.
  1. Stormin' Norman
    I bought a new rebuilt starter last fall. I saw the wear on the ring gear, but it was November and too cold to fiddle with it. When I got the 1978 Donor car powertrain in, in December 2006 (-15C, 5F), I just dropped it in, bolted it and stopped until Spring of 2007.
    So here I am with the task at hand.
    It's a 3.3L I6, C4 Auto. Doing a quick check on the web is kinda useless, because its mostly V8 (289/302) guys that are chatting about them, and they're talking about number of teeth, Std or Auto trans.
    I found a tidbit in the Haynes manual about removing the old ring gear with a hacksaw, using the chunks of the old one on bricks and heating up the new one to 400F with a torch (yellowish colour) and tapping the new one onto the flexplate. (Its separate from the converter and flywheel.)
    Andy suggested heating it up in the oven, and that makes good sense.
    TBird suggested buying a new one already mounted, because they get tackwelded to the flexplate.
    Then I saw a real monkeywrench article that Ford made the starter gear with 9 teeth, whereas the rebuilders often use a 10 tooth gear drive. Probably why mine is all chewed up.
    Bottom of thread:
    http://www.car-answers.com/Ford/Mustang/Ford-Mustang-1966-Making_Noise-Engine-075807.html
    Anyone have any idea who'd know how many teeth the Factory ring gear has AND the aftermarket ring gear might have?
  2. HandyAndy
    You want to come over and count my teeth?
    Stock teeth or falsies?:evilsmile:
    Which one has the motor off, I forget?
  4. Stormin' Norman
    Are you in tomorrow? or is today better?
  5. HandyAndy
    Nah I was just trying to be funny. I am not that lazy that I can't go downstairs and count 'em.
    132. Maybe we should get two, mine's a little chewed up as well.
  6. Stormin' Norman
    How many on the starter gear drive? 9 or 10?
    Yeah, let's get two. Probably need to ask ACE Electric about tooth count for a good match.
  7. HandyAndy
    :hmmm: Weird, I counted 11?
    And I have seen the ring gear referred to on the net as having 136 teeth?
  8. Stormin' Norman
    Where else can we check? Parkside Ford has the old microfiche cards still. Maybe Fordsix.
    Was the 3.3L used in other Fords, like Mavericks?
  9. HandyAndy
    OK Rockauto has the Dorman flexplate with 132 teeth, so we're OK with that.
    The starters they list are 9 teeth, so that's something to sort out. Maybe this car came with the wrong starter.
  10. Stormin' Norman
    I just searched FordSix. No Love.:( Just guys doing swaps with C3 and C4's on 250 CID sixes.
  11. Stormin' Norman
    Worse comes to worse, we get the right gear drive and the 132 ring gears. ACE or Ford for crossreference? Both probably.
  12. Stormin' Norman
  13. Stormin' Norman
  14. Stormin' Norman
  15. Stormin' Norman
