Engine Noise
Discussion in 'General Automotive Tech' started by mdelisi, Nov 7, 2011.
  1. mdelisi
    mdelisi New Member
    All,
    I have a 66 Mercury Colony Park with what I believe is a 68 Ford 390 in it. Recently the engine started "chirping" for lack of a better term. High pitched and it increases (and kind of goes away) with RPM increase. But it's pretty loud at idle. Any ideas? I'm thinking try tightening the belts first.
    Thanks for any help here.
    Mark
  2. 1964countrysedan
    Texas
    Belts
    Water pump
    A/C pulley/clutch assembly
    Fan clutch
    Fuel pump (more of a clicking)
    Let us know what you discover.
  3. Eagle Freek
    Eagle Freek Well-Known Member
    Also check alternator bearing and any idler pulleys. Take the belts off and spin stuff by had and see if you can hear or feel anything.
  4. Krash Kadillak
    Yeah, my first thought was a loose belt.
  5. 1967 Tempest
    NPR, Florida
    Squealing
    You would be surprised how many sources under the hood can make this sound. The thing with high pitch is that it is easy "covered". Meaning if you put your hand over a subwoofer, you are still gonna hear and feel bass. But if you put your hand over a tweeter, you will not get the highs.
    Using this method, can make quick work of localizing the chirp/squeal. Cut the engine in half. front and rear. Then left and right.
    Hope that helps. Been there many times. You can try a mechanics stethoscope, but you might not hear anything due to the nature of a HIGH pitch.
    Dave
  6. HandyAndy
    I too will go with alternator bearings.
    What do we win if we're right? :evilsmile:
  7. mdelisi
    mdelisi New Member
    Thanks all - the strange thing is I replaced the Alternator about 2 months ago. I guess it could go that soon if it was not a good one? One other thing - when I put it in reverse, the noise reduces quite a bit. Not sure if that says anything. I had the tranny rebuilt over the summer
    One more question: How do I determine what engine is in the car? I know it was swapped out and I believe it's a 67 or 68. Any way I can definitively tell through a serial number? If so, where is it located and how do I decode it?
  8. 1964countrysedan
    Texas
    Post a picture
  9. HandyAndy
  10. 1964countrysedan
    Texas
    So... What was the squeakin' ?
  11. mdelisi
    mdelisi New Member
    I have not gotten to it yet unfortunately. But I'm hoping over Thanksgiving to get some time. I'm going to pull the belts first one at a time and see if that makes a difference. Then I'll start digging into water pump, fan clutch if that doesn't show something. Attached a pic of the engine - I asked the previous owner and he said it had a 68 390 Ford engine swapped in.
    Thanks for the ideas and help here!
  12. mdelisi
    mdelisi New Member
    Starter?
    Ok, so I did some troubleshooting: on the engine chirping noise when I start up and run. I pulled the belts and the chirp is still there - so not the alternator or power steering pump. Now when I turn the key I'm getting a serious loud grinding noise. And then eventually after a few tries and jiggling the gear shift lever it will start.
    So question is twofold: 1) is the chirping a starter going bad? and is the grinding noise when I turn the key the starter itself, or a switch? something else? and, 2) do you think the chirping noise I hear when the engine is running is related to the starter? How hard is it to replace?
    Thanks for any ideas here.
  13. HandyAndy
    Hopefully it is just the starter.
    The gears on it mesh with a ring gear, and if the ring gear teeth are getting worn that would mean either dropping the tranny or pulling the engine.
    I've never done a V8 so I can't speak to how easy it is. The hard part may be access.
    Might be easier from underneath. Might be tranny cooler lines in the way.
  14. mdelisi
    mdelisi New Member
    Ok, thanks. Good news on that front is I just had the tranny rebuilt, so I think I'm still under warranty on that one. I'll go the starter route first.
  15. HandyAndy
    Yah just get a new one.
    There might be a high-torque mini starter replacement available.
