attn: 64-67 vista owners
Discussion in 'Station Wagon Projects' started by l6conv, Mar 16, 2014.
  1. l6conv
    l6conv Member
    conover nc
    I'm finally putting the 67 vc back together. So far I have the dash ,steering column and all the wiring from firewall to taillights.Everything works except radio( no power from yellow feed) and the dome lights don't work right. My question is ,Should the dome lights work when opening the front doors. Right now they only work when opening the rear doors. I would think all lights would work with either front door open. Let me know how yours work. Thanks Tony
  2. Vista
    Vista Well-Known Member
    Gainesville, FL
    The short answer is yes. My 67 only has the switches for the front doors. The rears were never installed by the factory. My other 67 does have them.
  3. l6conv
    l6conv Member
    conover nc
    So you're saying the dome lights will work when either front door is open? Mine only work when the rear door is open.I guess I'll have more trouble shooting to do. Any other A body wagon owners have the same problem.
  4. MikeT1961
    Base model equipment was for the either front door to operate the interior courtesy lights. The switches on the rear doors were part of either a "Convenience Package" or "Light Package", but the front door switches were still operational.
  5. whiskey runner
    whiskey runner Active Member
    south missouri
    check the ground switch on the door post..since the rears work the problem should be there..unless a wire is broken
