Adding guages to Old's Y block
Discussion in 'General Automotive Tech' started by 68GS400, Jan 25, 2012.
  1. 68GS400
    68GS400 New Member
    Marietta, GA
    I want to add water, oil, and volt gauges to my wagon. Volt and oil are no problem. Water temp is...I can't find a opening in which to put the temp sender under all that emissions piping. Anyone have a clue where to look: heads, block, intake? I can't use the existing sending unit locations due to emissions and engine control needs.
  2. BigBird87
    BigBird87 Well-Known Member
    Manchester, NH
    There aren't any plugged fittings in the intake manifold, block or heads, aside from the block drains, but those are too low down and not practical.
    I did the intake manifold gasket on my 307 not too long ago, so I had it all apart and saw nothing usable for that purpose.
    Does your radiator have a plug or two on the passenger side tank? That is the only thing I can think of.
  3. BlueVista
    Northeast Ohio
