'76 Ford Pinto with 2.3L turbocharged engine on eBay - Fenton, MO
Discussion in 'Car & Truck Talk' started by jim535, Mar 26, 2017.
  1. jim535
    jim535 born in a Ford
    Ottawa, Ontario
  2. Krash Kadillak
    From what I understand, the scoop is needed in order to clear the swapped-over '88 Turbo T-Bird setup, unless you want to do a lot of plumbing work........
  3. jim535
    Ottawa, Ontario
    Indeed, it looks like the hood was cut to clear the engine. At least they could have painted it to match. And it looks to be held in place with just four bolts. Or maybe self-tapping screws. :rolleyes:
    I actually kind of like this car. It might be a hoot to drive with some wider tires.
  4. Silvertwinkiehobo
    Throw some 14" Fox-body Mustang wheels with lo-pro tires, and some Koni's on all four corners. Then it'll be really fun.
  5. KevinVarnes
    It is cool, but not for $10k in my book. Given the hood scoop and the funky angle the clutch pedal is at and the automatic brake pedal (c'mon) I wonder about the rest of the work done to this thing.
