The front floor pans are the same as the 2 and 4 door cars,but the rear pans are different from under the rear seat bottom to the tailgate.. All Coronets had a 117 inch wheelbase, You can make the repop pans work by fabricating and adding your own to them r pans Besides it is my experience not all repop pans fit perfectly without some massaging or finesse with a BFH. Make sure you order for the Coronet since the Plymouth pans are again different from the shorter wheelbase 116" Plymouth wagons also had 117 inch wheelbase,FYI Nobody repops any wagon specific sheetmetal. Hope this helps. http://www.autometaldirect.com/ListItems/SubCategory/Floor/Pans.aspx
