I need to do some modifications to the harness, and I do not want to use electrical tape to wrap the harness. Anyone know where to get the factory type wrap?
Check out the two sites he shows on that main page too. http://www.centechwire.com/ http://www.wire-works.com/
I did, lots of cool stuff. I like the relay kits. I need to do the relay upgrade on mine for the headlights. I also have a 3g alternator to install, all I need is a ANL fuse holder. And I also have a mark 8 electric fan to go install..
What's an ANL fuse holder, the blade type? As in Lincoln Mark 8 electrical fan? Pretty good is it? I don't like all the heat that the Six generates. This is also good for the Headlight relays: http://www.rowand.net/Shop/Tech/WiringHeadlightRelays.htm
Yeah lincoln mark 8 fan, common OEM fan used for stangs, etc. A bit of heat is good, specially for economy. ANL is the big flat wafer type, looks like it's really common on boats. More good info! Thanks!
